Rotax is pretty much the gold standard for 2-stroke engines, and even though they're out of production, "like new" rebuilt engines are readily available. Either the 447 or 503 would likely do well in your application. The big single cylinder engines like the Victor are light and powerful, but they vibrate a lot. A half VW might work if you can live with 85 lbs.
